BMW 1M Full Specs
BMW 1M Full Specs
For those of you technical aficionados out there, here are the specifications for the new 1M. It shares the track of the M3, front and rear to the millimeter according to M Brand Manager NA, Matt Russell. Of note is the four inch shorter wheelbase than the 1M sports over the M3.
And for those of you that missed our comprehensive test drive of the 1M, here are some of our thoughts from the track:
“The 1M on the track is addictive. It’s a combination of great sounds, great chassis, and a thoroughly well matched powerplant to the car. It’s shorter wheelbase makes it just that much more nimble than larger cars and all of that torque, available almost off idle this will make the 1M a killer on any track with a surfeit of slow speed corners. This thing is nasty quick, it just digs hard out of the corners. Go wide open throttle and you’ll get the additional torque from the overboost function for about five seconds, enough to propel you headlong into the next corner.
ImageBut it all comes back to how easy this car is to drive. It’s forgiving, sure footed, exceptionally quick, with a brilliant set of brakes and great steering and steering feel. If you ever intend to do track days (and especially if you’re a track day junkie) this car has to be at the top of the short list.”
If you’re still not convinced this is a true M car, have a look at the technical specs below.
Chassis and SuspensionCodification of Reference Gearbox -KGear RatiosI-4.11II-2.315III-1.542IV-1.179V-1VI-0.846VII--Reverse Ratio-3.727Final Drive Ratio-3.154Steering Type / Ratio-Rack-and-pinion / 12.5Front Brakes / Diameter- / mm / inchVent. Disc / 360 / 14.2Rear Brakes / Diameter- / mm / inchVent. Disc / 350 / 13.8Tire Type, Front-245/35 ZR19 93YTire Type, Rear-265/35 ZR19 98YTire Type, Front w. Sport Package-naTire Type, Rear w. Sport Package-naWheels, Front-9.0J x 19 Light alloyWheels, Rear-10.0J x 19 Light alloyWheels, Front w. Sport Package-naWheels, Rear w. Sport Package-naPerformanceTop Speedkm/h / mph250 / 155Top speed w. Sport Packagekm/h / mphnaAcceleration, 0-60 mphs4.7Acceleration, 0-100 Km/hs4.9Fuel Economy, EPA Estimate – Citympg19Fuel Economy, EPA Estimate – Highwaympg26Fuel Economy, EPA Estimate – Combinedmpg21Approximate Rangekm / miles475 / 300EngineN54B30T0Type / Cylinders / Valves per CylinderInline / 6 / 4 VANOSEngine Management SystemBMW MS D81 Direct InjectionInduction SystemTwin turbo w/ overboostBoost Pressure / Overboostbar0.8/1.0Displacementcm³ / inch³2979 / 181.8Strokemm / inch89.6 / 3.53Boremm / inch84 / 3.31PowerSAE hp / rpm335 / 5800Torque *Overboostft lbs / rpm332 – 370* / 1500Compression Ratio / Fuel type10.2 / PremiumBodyPreliminaryNo. of Doors / Seating Capacity-0.5Vehicle Lengthmm / inch4373 / 172.2Vehicle Widthmm / inch1803 / 71.0Vehicle Height. Unloadedmm / inch1420 / 55.9Wheelbasemm / inch2660 / 104.7Turning Circlem / ft115 / 37.7Track, Frontmm / inch1541 / 60.7Track, Rearmm / inch1541/ 60.7Width at Shoulderheight, Frontmm / inch1372 / 54.0Width at Shoulderheight, Rearmm / inch1357 / 53.4Effective Leg Room, Frontmm / inch1053 / 41.5Effective Leg Room, Rearmm / inch816 / 32.1Effective Head Room, Frontmm / inch962 / 37.9Effective Head Room, Rearmm / inch943 / 37.1Trunk Volume acc SAE1100ft³10Fuel CapacityL / gal53 / 14Curb Weightkg / lbs1495 / 3296Weight Distribution Front/Rear%51.7 / 48.3Gross Vehicle Weight Rating (GVWR)kg / lbs1930 / 4255Payloadkg / lbs360 / 794Axle Load Limit, frontkg / lbs940 / 2072Axle Load Limit, rearkg / lbs1030 / 2271
Source: http://www.bmwblog.com/2011/05/13/bmw-1m-full-specs/
