Hi, i'm having problem with my M43's idle most of the time it runs very good and all of a sudden idle jumps from 200 to 1200rpm when ever i stop in lights. I have noticed that when ever it's going to happen it is sluggish and smell of fuel is around from the exhaust tip. I have done already some service to most things like ICV, O2 sensor, TB.
Thanx,
Rough Idle
Rough Idle
2002 C200 KOMPRESSOR
1995 318i - M42B21 Project Car on going
1992 325i AC Schnitzer - SOLD in DXB
1990 525i - SOLD in DXB
1989 M6 - SOLD in DXB
hey frost_dxb,
did you ever figure out what was wrong?
I would have thought that the ICV cleaning would have fixed it. Have you checked for air leaks?
cheers
cheers
Did you ever get this sorted out? I was having a few idle issue a little while back and there was a vacuum leak where one of the hoses was lose. If the problem is still going on then I'd suggest searching all over for an air/vacuum leak. This was enough to stall out my car, but it was an easy fix for me.
