New alarm...bypass the factory fitted imobiliser...or not?
(1991-1999)
chrismcl06
n00b-1st Gear
n00b-1st Gear
Post by chrismcl06 »
Hi I am buying a remote start alarm system am just curious as to whether i have to bypass the factory fitted imobiliser because the alarm comes with an imobiliser.
i'm not positive, but i think it should pretty much be plug-n-play. is the alarm that you are buying made specifically for your car's make/model? if so then you shouldn't have to by pass anything, and everything should just wireup like normal. i haven't installed an alarm before but that is my guess.
here's just a few links that might help you with the installation process and maybe help explain your question...
BMW OEM Alarm Installation (E36/S50)
http://www.bimmerdiy.com/diy/e36s50alarm
Aftermarket Alarm Double-Lock aka ANY Alarm Can Double-Lock
http://www.understeer.com/doublelock.shtml
Installing Alarm And Solving E36 Common Problems
http://forums.bimmerforums.com/forum/sh ... ight=alarm
hope that helps some! cheers[/url]
