ALPINA B7 In Motion
ALPINA B7 In Motion
Jim over at DrivesTV sent in some cool footage of the ALPINA B7. The 3 minutes video takes us in and around the car, as well as plenty of in-motion shots.
The BMW ALPINA B7 made its North American debut at the Chicago International Auto Show in 2010 and sells in the US for $122,875 (standard wheelbase) and $126,775 (extended wheelbase).
The B7 sedan is equipped with BMW’s twin-turbocharged 4.4 liter, all-aluminum, High Precision Direct Injection V-8 engine which has been enhanced by ALPINA and is capable of producing 500 (373kW) horsepower and 516 lb-ft (700Nm) of torque. This rear-wheel drive performance/luxury Sedan achieves 0-60 mph in 4.5 sec. With maximum torque available across an unusually broad engine range, from 3,000 to 4,750 rpm, the B7 accelerates effortlessly from virtually any speed.
ImageThe B7 sedan is finished with ALPINA aerodynamic developments, including front and rear spoilers which not only enhance the appearance but also improve stability and performance at high speeds. In true “form-follows-function” fashion, the ALPINA front integrates the fresh-air requirements of the transmission and engine oil coolers, which are separated out of the main cooler module for improved efficiency. The spoilers reduce lift at the front by 30% and rear by15%. The exhaust system’s two double tailpipes are seamlessly integrated into the rear bumper. The newest evolution of the traditional 20-spoke ALPINA Classic wheels gives the B7 a distinctive appearance and powerful stance.
The interior of the B7 sedan features ALPINA blue illuminated door sill trims, Switchtronic heated steering wheel in hand-stitched Lavalina leather, Alcantara headliner, Heads Up display, and the Black-Panel LCD screen instrument cluster branded with ALPINA. Hand-stitched Lavalina leather also covers the dashboard, door panels, center console, multi-contour front seats with heating and cooling, and heated rear seats.
To learn more about the ALPINA B7, follow the link.
Source: http://www.bmwblog.com/2011/01/16/alpina-b7-in-motion/
