EVO’s Chris Harris loves the BMW 1 Series M Coupe
Well-respected and known journalist Chris Harris had a chance to spend some time behind the wheel of the new BMW 1 Series M Coupe.
As always, Harris goes through a deep analysis of the “baby M car” and shares a checklist on what the attributes of an M model should be.
Before jumping into the video, here are some of the key points of the new, exciting 1M.
Despite its looks closer to the 135i Coupe model, the new 1 Series M Coupe is almost an entirely different car. Almost every suspension part is different. The springs are stiffer and the dampers have less travel, the bushings of the trailing arms are changed from rubber to joint balls and some rubber ones are stiffer.
Rendering by Jon Sibal
The suspension cannot be adjusted – also to keep the cost down. The front axle carrier is the same as in the 135i, but in the rear the one of the M3 is used.
The body is lowered by 10 mm (0.4 in) and the track is approximately 30 mm wider up front and between 30 to 40 mm wider at the rear. The brakes are completely different from the 135i Coupe with M Compound brakes.
BMW 1M is powered by an engine based on N54 twin-turbo delivering 340 horsepower. Engine is matted to a six-speed manual.
The new M makes its world debut at the 2011 Detroit Motor Show and it will be available in three colors: Alpine White, Jet Black and Valencia Orange Metallic.
Source: http://www.bmwblog.com/2010/11/03/evos- ... s-m-coupe/
