Autocar: BMW 1 Series M First Drive
More reviews of the BMW 1 Series M Coupe are going online. UK magazines are starting to publish their own impressions of the upcoming entry-level M coupe and Autocar is the first in line to tell us more.
What’s it like?
One thing’s for sure: the new M-car doesn’t lack shove.
Its engine is a development of the updated unit used in the Z4 sDrive35iS. As with so much of this car’s mechanical package, BMW is not divulging much about it at all. But with a host of typical performance-enhancing changes – including larger turbochargers, additional boost pressure and unique mapping – power and torque are said to be somewhere north of the Z4’s 335bhp and 332lb ft of torque.
ImageThe thing that grabs your attention as you pull away is its flexibility. It will accept sixth gear at 1000rpm without any unruly shunt and continue to pull hard towards the business end of the range without any dip in demeanour.
It’s under load in low gears, though, where it does its best work. Planting your foot in second induces the sort of rolling acceleration to match the 414bhp V8 M3 and it feels terrifically urgent right up to its 7000rpm limit.
Apportioning drive is a six-speed manual gearbox, the only choice for buyers. However, the car does get the same rear axle as the M3, complete with its electronically controlled M differential for more engaging driver appeal and big levels of traction. Nothing’s official, but expect a 0-62mph time of around 5.0sec and a top speed limited to 155mph.
Our prototype had clearly led a hard life and was not fully representative of the final production version of the new M-car, which makes its debut at the Detroit motor show in January before going on sale in the UK in May.
Still, there was sufficient evidence to suggest it will be stiff competition for the current crop of performance coupés. Changes to the suspension provide a noticeably more fluid feel than the standard 1-series, with more enthusiastic turn-in and added levels of grip. The electro-mechanical steering, for all its accuracy, delivers little feedback on centre but it is quite direct, at 2.4 turns lock to lock.
There’s a little initial roll, but the lightened body settles quickly to provide a flat cornering stance. And with that trick differential juggling drive between the rear wheels, you can lean on it at the exit without any premature breakaway or activation of the stability control system. The new BMW also rides acceptably, even on the 35-profile rubber fitted to our prototype. It’s firm, but not overly so.
Full article continuedImage
Source: http://www.bmwblog.com/2010/10/09/autoc ... rst-drive/
