Dinan S3-R M3 Revealed – 527 hp, 407 lb-ft +200 mph
Press Release: Dinan S3-R M3 Revealed. A 527 hp 407 lb-ft +200 mph monster when the pedal is to the firewall and a comfortable daily driver in bumper to bumper.
The M3 name by itself carries a lot of weight in the automotive world, sitting at the top of the 3 Series line as BMWs sportiest offering. An impressive car right out of the box, with details like a carbon fiber roof, powerful brakes and an electronically adjustable suspension that are reserved only for the M badge.
The Dinan S3-R M3 takes the M3 to a whole new level, hiding under the conspicuous hood is 527 horsepower and 407 foot-pounds of torque, up 113 horsepower from the stock engine.
The stock V8 engine is bored and stroked for a gain of 608cc of displacement. The Carbon Fiber High Flow Intake and bored out High Flow Throttle Bodies add more oxygen rich air while the Middle Racing Exhaust and the connected High Flow Exhaust let the spent gasses exit with ease. And the story does not end at the engine like so many of these stories do but continues on to the practical, with suspension upgrades to match the newly found power and the massive amount of rubber now beneath it.
Dinan’s wheel and tire combination put 275/30 tires on the front and 295/30 tires in the rear on a one piece forged wheel that weighs just 19 lbs, significantly reducing unsprung weight. To handle the power and torque delivered to the larger wheels the suspension was upgraded with new springs, front anti-swaybar, Carbon Fiber Front Strut Braces and Racing Rear Toe Links to put the power to the ground. The E92 M3 carries the tag line on the BMWNA website that “racecars shouldn’t be confined to race tracks”, Dinan could not agree more.
Inspired by 30 years of BMW performance tuning, the Dinan S3-R M3 features a carefully engineered, balanced high performance package for the M3, backed by the only warranty on the market that matches the manufacturer coverage for up to 4 years/50,000 miles. The Dinan S3-R M3 offers remarkable performance that can be enjoyed without the fear of compromising warranty coverage or the reliability expected of a BMW automobile.
Dinan S3-R M3 Available for E92, E90, E93 M3
Engine
  • Engine 4.6L V8 • Free Flow Exhaust (Rear Mufflers)
  • High Flow Throttle Bodies
  • Carbon Fiber High Flow Air Intake
  • Underdrive Crankshaft Pulley Kit
  • Middle Racing Exhaust
Maximum Horsepower: 527 @ 7800 rpm Maximum Torque: 407 lb-ft @ 5200 rpm Suspension
[*]Stage 3 Suspension System Includes: Performance Spring Set, Matching Front Bump-Stops, 28.5mm front anti-swaybar w/ urethane bushings, Front camber plates, Rear Upper Shock Mount Kit, Front Guide Supports[*]Carbon Fiber Front Strut Braces[*]Racing Rear Toe Link
Brakes
[*]Dinan/Brembo Front & Rear Brakes with black calipers & slotted rotors
Dinan Options Wheels and Tire
[*]Front Wheel: Dinan 19 x 9.5” Lightweight Forged Wheel Rear Wheel: Dinan 19 x 10” Lightweight Forged Wheel[*]Front Tire: 275/30-19 Michelin Pilot Sport II[*]Rear Tire: 295/30-19 Michelin Pilot Sport II
Accessories
[*]Dinan Aluminum Pedal Pad Set[*]Dinan Deck Lid Badge
[*]Dinan S3 Serial Numbered Plaque
Warranty
[*]Matching New Car Warranty coverage up to 4 years/50K miles. Except on “Racing” parts.
[Source: Dinan ]Image
Source: http://www.bmwblog.com/2010/03/18/dinan ... t-200-mph/
