Tecnocraft E9X ///M3 ENVY Intake System
BMW tuning fans rejoice: Tecnocraft introduces its first major step into European mass-market product in their release of the TECNOCRAFT E9X ///M3 ENVY™ Intake System. Designed from the ground up, all in-house, with a performance build strictly in mind, the dry carbon fabrication team set to work in producing the most comprehensive quality intake system BMW E92 ///M3 owners (and would-be owners) have ever seen.
This completely modular system consisting of four, separate and equally functional, pieces fabricated in 100% Dry Carbon (or in Carbon/Kevlar special edition for an added cost) can find its way into your ///M engine bay over time.
Technical Specifications
The complete ENVY™ Intake System gains horsepower and increases throttle response on both the dynamometer and real world use, as expected in all functional ram air intake systems – forward motion at over 60mph brings the performance of the ENVY™ to life.
Dynamometer: 15-19RWHP
Real world use: 20+RWHP
TECNOCRAFT E9X ///M3 ENVY™ Intake System includes the following (in order of primary airflow):
ENVY™ RAM Air Scoop
-Stage 1 of the ENVY™ intake system is a direct drop-in replacement of the plastic OEM intake bridge on E9X ///M3s. With a more highly effective design versus factory, especially at speed, the ENVY’s RAM Air Scoop ensures that a large volume of air can be force fed into a starved intake system. Also, since the RAM Air Scoop is fabricated in 100% DRY CARBON the goal was to maximally enhance airflow dynamics conforming to the tight space tolerances behind the ///M3 kidney grilles. Rest assured this goal was achieved and the largest RAM Air Scoop in the market for the E9X ///M3s are now readily available.
(OEM Replacement fit and finish), X oz. / $349.99)
ENVY™ Transition Chamber
-Stage 2 of the ENVY™ intake system is a direct drop-in replacement of the plastic transition pipe on E9X ///M3s. The main advantages of the ENVY™ Transition Chamber is the smooth delivery of intake charge from the RAM Air Scoop by its elimination of unnecessary notches and choked design points leading into the factory ///M3 airbox. Forced air makes its first contact with an organically designed transition chamber, which allows airflow from the ENVY™ Ram Air scoops to be naturally reservoired and transitioned smoothly from left to right. All unnecessary turbulence was eliminated in the ENVY™ Transition Chamber’s design and conforms to extremely tight tolerances to provide a dramatic volume increase to charged air.
ENVY™ Enlarged Intake Cover
-Stage 3 of the ENVY™ intake system is a direct replacement of the factory airbox cover on E9X ///M3s. While we consider the factory intake box design made available by BMW to be sufficient, another necessary step in a complete ENVY™ intake system was development of an Enlarged Intake Cover without the many unnecessary points of intake turbulence while also increasing total airbox volume by 30%. Our Enlarged Intake Cover design carries charged air in greater volume from the Transition Chamber up and over the factory or BMC filter (optional) smoothly, hindering disruption from air filter structure as much as possible before reaching the ENVY™ ChargePipe. Factory fitment in a 100% Dry Carbon product was necessary to ensure hood scoop function remains available to the entire airbox as well.
(OEM Replacement fit and finish), X oz. / $429.99)
ENVY™ ChargePipe
-The 4th and Final Stage of the ENVY™ Intake System is the ENVY™ intake system’s most highly sought after, direct replacement of the factory rubber chamber before the intake manifold. The ENVY™ ChargePipe eliminates the final and most important choke point in air intake charge while dramatically reducing turbulent airflow. Its extremely organic 100% Dry Carbon design allows for the largest and smoothest transition of air from the entire intake system, complimenting even the factory E9X ///M3 intake system where it is most needed. The ChargePipe is our featured highlight product of the ENVY™ intake system and is suggested by TECNOCRAFT to be a first investment towards a complete ENVY™ intake system if purchased as a standalone product. The ENVY™ ChargePipe has been specifically paired with a BMC filter as a perfect combination upgrade for the most noticeable throttle response, horsepower and torque gains of the entire ENVY™ system.
(OEM Replacement fit and finish), X oz. / $629.99 (no filter), $699.99 (///M3 BMC Filter)
Further information on the TECNOCRAFT And the E9X ///M3 ENVY™ Intake System:
With organic design elements taken from the highly praised TECNOCRAFT Lamborghini Gallardo ‘Hi-Flow Intake System’, keeping optimal airflow dynamics was a primary concern – having also been developed in 100% Dry Carbon, our intake systems are natural heatshields and do their part to greatly reduce heatsoak.
All parts of the ENVY™ system have been enlarged by at least 30% in volume, designed with smoothly transitions, and reduced in weight (if not all three at the same time) to ensure every ounce of horsepower can be gained while naturally aspirated.
PYSpeed is the exclusive distributor for Tecnocraft and more information can be found on their website.
Source: http://www.bmwblog.com/2010/02/22/tecno ... ke-system/
Users browsing this forum: Google [Bot] and 5 guests
