Download List
Post questions about files in the 'Downloads' section of the site. Also, suggest files you've found to add to the downloads page or request downloads.
Download List
These are the resources that are available for download from this site..
Articles
-Bavarian Autosport Fast Times
Summer 2003_n103_newsletter.pdf -314KB
Fall 2003_n203_newsletter.pdf - 257KB
Winter 2004_n104_newsletter.pdf - 440KB
Spring 2004_n204_newsletter.pdf - 551KB
Summer 2004_n304_newsletter.pdf - 572KB
Fall 2004_n304_newsletter.pdf - 457KB
Winter 2005_n105_newsletter.pdf - 630KB
Spring 2005_n205_newsletter.pdf - 857KB
Summer 2005_n305_newsletter.pdf - 426KB
Fall 2005_n405_newsletter.pdf - 536KB
Winter 2006_n106_newsletter.pdf -314KB
Spring 2006_n206_newsletter.pdf - 257KB
Summer 2006_n306_newsletter.pdf - 257KB
Fall 2006_n406_newsletter.pdf - 435KB
Winter 2007_n107_newsletter.pdf -438KB
Spring 2007_n207_newsletter.pdf - 1.87MB
-BMW CCA
"BMW CCA - Let There Be (E36) Light" and "Euro-So-Bright - August 2005" - articles/head_light_article.zip - 2.5MB
-BMW History in Russian
BMW History - bmw_history.pdf - 831KB
-Badger Bimmers Newsletter
Badger Bimmers Newsletter - badger_bimmers_newsletter.zip - 15.6MB
-Golden Gate Chapter Newsletter
Golden Gate Chapter Newsletter - golden_gate_chapter_newsletter.zip - 98.1MB
-Missouri Valley Chapter Newsletter
Missouri Valley Chapter Newsletter - Missouri_valley_chapter_newsletter.zip - 3.03MB
-NY Die Zugspitze Newsletter
NY Die Zugspitze Newsletter - ny_die_zugspitze_newsletter.zip - 21.4MB
Bimmerfest - twenty_years_of_the_bmw_m3.zip - 147KB
Avatars and Buddy Icons
-Avatars/Buddy Icons in a compressed file (all 1,363 icons) or individually
Electronic Troubleshoot Manuals
-3-Series E36 (91-92) ETM - 496KB
Description: Electronic Troubleshooting Manual for 1991-2 BMW 3-Series, more specifically the 318 Series. Contains wiring diagrams regarding: Engine Compartment & Headlights, Computer Engine Control, Fuse Block , Ignition Switch, A/C & Heater, Multi-Function Clock, Inter Lts, ABS, SRS, Seat Belt & SRS Warn Module, Comb Sw, Light Sw, Defog Sw, Pwr Antenna, Instrument Cluster, Pwr Widow/Mir, Wiper/Washer, Taillights, Power Windows/Door, Cntrl Locking Ctrl, Passenger Compartment & Taillights.
-3-Series E36 Compact ETM - 4MB
Description: Electronic Troubleshooting Manual for E36/5 Compacts (316i, 316g, 318ti, 318tds, 323ti) 1998 models. Although it was designed for the 1998 models, most of the information should be true for all matching compacts in the E36 models (1992-1999). Everything you need to investigate and fix technical problems!
See also "3-Series E36 Sedan ETM"
-3-Series E36 Sedan ETM - 5.74MB
Description: Electronic Troubleshooting Manual for E36 3-Series (316i, 318i, 318is, 320i, 323i, 328i, M3, 318tds, 325td, 325tds incl. Convertible and Touring) 1998 models. Although it was designed for the 1998 models, most of the information should be true for all E36 models (1992-1999). Everything you need to investigate and fix technical problems!
See also "3-Series E36 Compact ETM"
5-Series E34 - (1994) - 19.1MB
Description: Electrical Troubleshooting Manual for E34 5-Series (518i, 520i, 525td, 525tds, incl. touring) 1994 models. Although it was designed for the 1994 models, most of the information should be true for all E34 models. Everything you need to investigate and fix technical problems on your E34! Contains the following information: Index, Introduction, Symbols, Power distribution chart, Fuse chart, Power distribution, Fuse details, Ground distribution, Diagnostic link, Digital motor electronics (DME M1.7,4-cylinderM40), Engine management MS40 (6-cylinder M50), Preheating system, Alternator, Starter, Digital diesel electronics (DDE 2, 6-cylinderM51), Electronic transmission control (EGS A4S 31 OR), Electronic transmission control (EGS ASS 31 OZ), Electronic transmission control (EGS ASS 31 OZ diesel), Electronic steering column control, Airbag (AB), Servotronic, Antilock brake system (ABS), Power mirrors, Door lock heating (ZKE/TSH), Door lock heating (ZVM/TSH), Central locking system (ZKE/ZV), Central locking module (ZVM), Power windows (ZKE/FH), Electric sun shades, Power seats, Heated seats, Lumbar support, Sunroof (ZKE/SHD), Double-panel sunroof (ZKE), Double-panel sunroof (ZVM), Central body electronics (ZKE), Horn, Windscreen wipe/wash system (ZKE), Wipe/wash module (WWM), Rear window wipe/wash system, Headlight washer (ZKE/SRA), Windscreen washer Jet heaters, Instrument cluster (redesigned standard version), Clock, Multi-function clock, Light switch, Headlight/fog light, Turn signal/hazard warning system, Park/tail/under hood lights, Licence plate/luggage compartment lights, Reversing lights, Brake lights, Trailer coupling, Interior light control (ZKE/IB), ZVM Interior lights, Interior, Crash and alarm sensor, Automatic heating control (HR34) - digital, Automatic heating control (IHRF3), Independent heating/ventilation with IHKA, Independent heating/ventilation with HR34, Independent ventilation with IHKA, Independent ventilation with HR34, Independent heating/ventilation with IHRF3, Independent ventilation with IHRF3, Independent heating/ventilation with IHKR/F3, Independent ventilation with IHKR/3, Rear window defogger/antenna, Automatic circulating air control (AUC), Automatic climate control (IHKA), Automatic climate control with filter (IHKR/F3), Auxiliary fan, Radio/stereo, Radio/HiFi, Radio provisions, Cellular telephone, Cruise, Control, Anti-theft system III (DWA III), On-board computer (BC IV), Infrared locking system (IR), Park distance control (PDC), Component location chart, Component location views, Solder connector location views, Connector views.
-5-Series E34 524td - 79KB
Description: Wiring or fuse guide for the E34 5-Series 524tds. Please email me if you know exactly what this guide is and have some description I can use to better explain it! Thanks.
-5-Series E34 525 - 1.58MB
Description: Electronic Troubleshooting Manual for 1991-2 BMW 3-Series, more specifically the 318 Series. Contains wiring diagrams regarding: Engine Performance Circuits, A/C Circuit, Anti-lock Brake Circuits W/ Traction Control, Anti-lock Brake Circuits W/O Traction Control, Auxiliary Cooling Fan Circuit, Charging Circuit, Cruise Control Circuit, Data Link Connector Circuit, Defogger Circuit, Electrical Box Fan Circuit, Electronic Power Steering Circuit, Ground Distribution Circuit, Headlamp/Fog lamp Washer Circuit, Headlight Circuit W/ DRL, Headlight Circuit W/O DRL, Heated Seats Circuit, Horn Circuit, Instrument Cluster Circuit, Jet Heater Circuit, Memory Mirrors Circuit, Memory Seat Circuit, Photochromic Mirror Circuit, Power Distribution Circuit, Power Door Lock Circuit, Power Mirror Circuit, Power Seats Circuit, Power Window Circuit, Radio Circuits, Starting Circuit, Transmission Circuit, Wiper/Washer Circuit.
-7-Series E32 735 (1991) ETM - 851KB
Description: Electronic Troubleshooting Manual for 1991 E32 7-Series 735. Although it was designed for the 1991 models, most of the information should be true for all E32 735 models and maybe other E32 models. Contains wiring diagrams regarding: Engine Compartment & Headlights, Computer Engine Control, FNT PDB (Partial), Ignition Sw, Horn Sw, AUX Fuse Box, Phone, Rear Power Distribution Box, Anti-Lock Brake System, ETC Unit, A/C & Heating Control System, Wiper/Washer, Cruise Control, SRS System, Light Control System, Crash Control Unit, Inst Cluster, A/T Range Sw, Vehicle Speed Sensor, Check Module, Anti-Theft Sys, OBC, Door Lock, Relay Module, General Module, Power Windows, Dome/Map Reading Lt Assy, Memory Seat/Mirror System, Power Seats/Heaters, Infared Locking Unit, Power Mirrors, Sunroof, Antenna, Taillights.
Owners Manuals
-Pre-1998 Manuals
Sorry, I don't have any owners manuals for these year. If you have any please share it with me so I can share it with the rest of the bimmer community on my site!
-1999 Manuals
7-Series E38 Owner's Manual (1999) - 1.7MB
Description: E38 7-Series Owner's Manual for the vehicle. Models 740i, 740iL, and 750iL. Covers: Overview, Controls and features, Operation, care and maintenance, Owner service procedures, Advanced technology, Technical data, Index.
-2000 Manuals
3-Series Convertible
Description: E36 3-Series Owner's Manual for the vehicle. Models 323i and 328i. Covers: Overview, Controls and features, Operation, care and maintenance, Owner service procedures, Advanced technology, Technical data, Index.
3-Series Coupe
Description: Download available. Description coming soon!
3-Series Sedan
5-Series Sport Wagon
7-Series
M-Series M5
X-Series X5
-2001 Manuals
3-Series Coupe
3-Series Sedan
3-Series Wagon
5-Series Sedan, Sport Wagon
7-Series
M-Series M3
M-Series M3 Convertible
M-Series M5
M-Series M-Roadster Coupe
X-Series X5
Z-Series Z3
Z-Series Z8
-2002 Manuals
3-Series Sedan
3-Series Coupe
3-Series Touring
5-Series E39 Owner's Manual [Saloon, Touring Coupe] (2002) - 27.2MB
Description: E39 5-Series Owner's Manual for the vehicle. Models 520i, 523i, 525i, 530i, 535i, 540i, 520d, 525d, 530d incl. Saloon and Touring.
7-Series (745i, 745Li)
M-Series M3
M-Series M5
X-Series X5
Z-Series Z3
Z-Series Z8
-2003 Manuals
3-Series Coupe
3-Series Sedan
3-Series Sport Wagon
5-Series
7-Series
M-Series M3 Coupe
M-Series M5
X-Series X5
Z-Series Z8
-2004 Manuals
3-Series Coupe
3-Series Sedan
3-Series Wagon
5-Series
7-Series
M-Series M3 Coupe
X-Series X3
X-Series X5
Z-Series Z4
-2005 Manuals
3-Series
5-Series
6-Series
7-Series
M-Series M3 Cabrio
M-Series M3 Coupe
X-Series X3
X-Series X5
Z-Series Z4
-2006 Manuals
Sorry, I don't have any owners manuals for this year yet. Coming soon!
Pictures
-BMW Wallpaper Collection - 412 Wallpaper Images! - 42.8MB
Screen Savers
-BMW Bounce v1.0 - 791KB
File Type: Setup EXE
Description: Large BMW logo moves smoothly across the screen continuously bouncing off the sides of the screen.. Traditional style screen saver. Plain black back ground.
-BMW Bounce v2.0 - 783KB
Description: Large BMW logo moves across the screen smoothly bouncing off the sides of the screen., but randomly changes speeds and directions. Plain black back ground.
-BMW Collision v1.0 - 810KB
Description: Large BMW logo collides with smaller BMW logos, setting them all into motion. Both the large and small logos bounce off the sides of the screen. Fades black to orange to black in the back ground.
-BMW Collision v2.0 - 791KB
Description: Large BMW logo collides with smaller BMW logos, setting them all into motion. The large logo bounces off the sides of the screen while the smaller logos exit the screen and re-enter from the opposite side. Fades black to blue to black in the back ground.
-BMW Collision v3.0 - 791KB
Description: Large BMW logo collides with smaller BMW logos, setting them all into motion. Both the large and small logos bounce off the sides of the screen. Fades black to blue to black in the back ground.
-BMW Collision v4.0 - 791KB
Description: Large BMW logo collides with smaller BMW logos, setting them all into motion. Both the large and small logos bounce off the sides of the screen. Plain black back ground.
-BMW Collision v5.0 - 791KB
Description: Large BMW logo and smaller BMW logos are all started in motion at the start, continuously colliding with one another. Both the large and small logos bounce off the sides of the screen. Plain black back ground.
-Please suggest ideas for screen savers as I will try to implement your suggestions as best as I possibly can. I will also include that the design was your original idea and give you credit for it. Please send pictures if possible that you want me to use in the screen saver. Thanks for every-one's support!
BMW Service & Repair Manuals & Schematics
-3-Series E21 Schematics Catalogue - 7.02MB
-3-Series E36 Bentley Service Manual - 92.7MB
-3- & 5-Series Haynes Service and Repair Manual - 7.2MB
-5-Series E34 Bentley Service Manual - 61.2MB
-Bentley Inspection I Check List - 11.4KB
-Bentley Inspection II Check List - 12.1KB
-Bentley Oil Service Check List - 10.2KB
-Brakes (1983) 318i, 320i, 528e, 533i, 633CSi, 733i - 253KB
-Chilton's 1996 Import Car Manual 1992-96 - 20.8MB
-Circle BMW - BMW Remote Control Security System - 358KB
-Cruise Control Actuator - Technical Data - 2.3MB
-Retrofit Kit On-board Monitor and Navigation System - 7-Series (E38) - 1.06MB
Software
-CarSoft 6.5 - 24.9MB
Zipped | Install Files
Sorry, I currently have no information about the cable required for this software. However, you can take a look at the company's website who makes this software here...http://www.mavericktechnology.co.uk/mai ... ft_bmw.htm ...as I am not affiliated with them at all.
-ETK - Electronic Parts List Disc 1 (01/2005) - 453MB
Image Type: IMG/CUE/CCD
-ETK - Electronic Parts List Disc 2 (01/2005) - 359MB
-ETK - Electronic Parts List Disc 1 - 332MB
Zipped | Install Files & Folders
-ETK - Electronic Parts List Disc 2 - 266MB
-ETM - Electronic Troubleshooting Manual E28 & E34 (5-Series), E24 (6-Series), E23 & E32 (7-Series) - 494MB
-ETM - Electronic Troubleshooting Manual E30 & E36 (3-series including Z3), E31 (8-Series) - 396MB
-KSD - Job Time Costing System - 335MB
-TIS - Technical Information System - 437MB
-TIS - Technical Information System (01/2005) - 543MB
-TIS - Technical Information System (12/2004) (Multi-language) - 549MB
Image Type: BIN/CUE
Sound/Audio Clips
Air Intake Sound Clips
-De-baffled 92 325i - 55mph to Full Throttle - 498KB
-De-baffled 92 325i - Standing In Front - 332KB
-Cold Air Intake (Type Unknown) - 1.21MB
-- This sound clip was found in a thread at BimmerWerkz.com (specific thread can be found here).
-DTM Exhaust Clip (Home Video)
Video clip used as sound clip
-Exhaust Sound Clips
Stock System - mp3
-ANSA (second baseline used) - mp3
http://www.europeancarweb.com/tech/0301 ... index.html
-B&B TriFlo - mp3
-HIOP/evosport - no mp3 available yet
-HKS (second baseline used) - mp3
-Racing Dynamics (second baseline used) - mp3
-Rogue Engineering (second baseline used) - mp3
-Supersprint DTM--2.5-in., silver - mp3
-Supersprint--2-in., black - mp3
-UUC System U--Single Canister - mp3
-UUC TSE--Twin Canister - no mp3 available yet
-Random BMW Clips
BMW E36 M3 Squeals Tires - 1.96MB
Videos
BMW 1-Series 1 Views
Aldo in a BMW 1series
Descriptions coming soon.
BMW Commercial Altered (Portuguese)
Hartge H1 5.0
Hartge Upgraded BMW 1-Series
BMW 3-Series 1 Views
87 325iC cabrios e30 BMW M Technik Mtech
Ansi guys brand new 2006 BMW
Automated Parking in a BMW
BMW (E90) Hartge H50 V10 Road Test
BMW 3-Series Commercial
BMW 3-Series Commercial 2
BMW 3-Series Commercial 3
BMW 3-Series Commercial 4
BMW 3-Series Commercial 5
BMW 3-Series Coupe - Casual Driving on Highway
BMW 320d racing Mercedes
BMW 328 Drift and 180
BMW 330D vs MGF
BMW 330D vs Toyota MR2
BMW 335i TV Commercial
BMW Commercial featuring Anna Kournikova
BMW e30 m20b25 1987/89 325iC M Technic
bmw e30 v8
bmw e30 v8 coming back
Bmw E30 V8 Drift
BMW E36 318 DTM Exhaust
BMW E90 Hartge H50 V10
Bmw m3 E30 drift
bmw m3 hartge h50 e46
BMW M3(E46) vs. Alpina B3 vs. Hartge 5.0
BMW Reflections Commercial
Dutch Supercar Challenge - Rolf Van Os - BMW 320 STW
m5board.com presents: Hartge H50 V-10 Part II: 300 km/h run
m5board.com: Hartge H50 5,0 E90 Part I
BMW 5-Series 1 Views
BMW M5
BMW M5 & M6 (French)
BMW M5 - Ramy serry super drift
BMW M5 Commercial
BMW M5 Drifting
BMW M5 Dyno
BMW M5 on Track
BMW M5 Smokes Us
BMW M5 Test Driving
BMW M5 VS. BMW M6
BMW M6 versus BMW M5
m5board.com trailer: upcoming Hartge H50 V-10 5.0 videos
Playing with a BMW M5 on a Wednesday afternoon
BMW 6-Series 1 Views
BMW M5 Desert Commercial
BMW M5 VS. BMW M6
BMW M6
BMW M6 Compared to Competitors
Top Gear BMW 645i Porsche 911 and Jaguar XKR - Part 1
Top Gear BMW 645i Porsche 911 and Jaguar XKR - Part 2
Win a BMW M6 Cabriolet - Bubble Wrap TV Episode 4
BMW 7-Series 0 Views
2006 BMW Hydrogen 7 Series promotional video
2006 BMW Hydrogen 7-Series refuelling promotional video
BMW 7 Series Facelift
BMW 7-series circuit
BMW 7-Series Night Vision
BMW 700LS Ad
BMW 750i v12 Top Speed
BMW Series 7
BMW Serie 7 Commercial
Chris Cunningham commercials - BMW 7-Series
Mahmoud + BMW 7 Series = OMG
BMW 8-Series 0 Views
1ª Concentración BMW 850
BMW 850 (Parte 1) 2ª KDD BMWFAQ - España
BMW 850 (Parte 10 de 15) 2ª KDD BMWFAQ - España
BMW 850 (Parte 2) 2ª KDD BMWFAQ - España
BMW 850 (Parte 3) 2ª KDD BMWFAQ - España
BMW 850 (Parte 4) 2ª KDD BMWFAQ - España
BMW 850 (Parte 5) 2ª KDD BMWFAQ - España
BMW 850 (Parte 6) 2ª KDD BMWFAQ - España
BMW 850 (Parte 7) 2ª KDD BMWFAQ - España
BMW 850 (Parte 8) 2ª KDD BMWFAQ - España
BMW 850 (Parte 9) 2ª KDD BMWFAQ - España
BMW M1-Series 0 Views
30 Years of BMW M Power
BMW EARLY M-Cars + MOTORSPORT Documentary M1 M3 M5 CSL
BMW M3 E36 vs Corvette Z06
BMW M5 Drifting in Parking Area
BMW M5 E60 Drifting in Germany
BMW M5 E60 Racing a Modified Ferrari F430
BMW M5 Highway Drift
BMW M5 vs Audi RS4
Dinan BMW M5 E39 vs BMW M5 E60
Drift Challenge BMW M3 E36 Dakar Yellow
Fifth Gear BMW M3 CSL
M Car Origins
M3 Vs RS4 Drifting Fifth Gear (spanish subs)
Top Gear - BMW E46 M3 vs. B5 Audi S4
Top Gear - BMW M5 drifting
Top Gear - BMW M5 Taxi - One lap around the Nurburgring with Clarkson
Top Gear Hot Saloons - BMW M5, Jaguar XJR, etc.
VLN8 Bilstein Land
BMW M3-Series 2 Views
Bmw E30 M3 Turbo World Record
BMW E30 M3 vs Police Camaro
BMW M3 GTR
BMW M3 turbo vs Ferrari 360
Fifth Gear - BMW E30 M3 vs Lancia Delta Integra
BMW M5-Series 1 Views
BMW M5 Drift on highway
BMW M5 Drift on Track
BMW M6-Series 0 Views
BMW M6 with Supersprint Exhaust on Dyno
BMW M-Coupe Series
BMW X3-Series
BMW X3 Inspection
BMW X3 xDrive Commercial
BMW X5-Series 2 Views
BMW - Defining innovation - commercial
BMW Formula Video
BMW HP2 at Erzberg Rodeo 2006
Kids in BMW Holiday Commercial
The Switch
The Switch 2
The Switch 3
BMW Z3-Series 0 Views
BMW Z3 Commercial
BMW Z3 Roaster Commercial - German
BMW Z4-Series
BMW Z8-Series 0 Views
Top Gear BMW Z8 by Alpina
BMW General (Extra)
-BMW Films - The Hire DVD
(Not available for download at this time. Please ask questions in the Forum if you have a question about this file.)
MD5 Hash: DDE857DA18E08BC081318BB7A0A6A2C2
Disc Image - 4.27GB
Description (taken straight from BMWFilms.com): Quote"BMW's groundbreaking The Hire film series ignored conventions and created the phenomenon known as online films. The Web has never been the same since. These eight short films by critically acclaimed Hollywood directors effectively revolutionized the world of interactive entertainment, while showcasing the absolute limits of automotive high-performance exclusive to BMW. Over 100 million film views and numerous awards later, The Hire film series served as further proof that when it comes to innovation and technology, BMW has always been ahead of its time.
Please note that The Hire Films series is no longer available for download or purchase."
BMW Films - The Hire DVD broken down into 500MB chunks. Total zipped size: 3.82GB
-Chunk One 500MB Hash: A11302528B03DBA45EFBFB0A57B9C94C
-Chunk Two 500MB Hash: 6D0A7A213B50C64143D043B2F6AC2C8D
-Chunk Three 500MB Hash: 548BC9C914B1690C8A1A7863515233FA
-Chunk Four 500MB Hash: 591E27882C2B96A70D5FB49C486E7B29
-Chunk Five 500MB Hash: 2846711AC2CA651B83D4AE10CAAE0D78
-Chunk Six 500MB Hash: CE275A9D3D5A733078D052CE0C32FF8E
-Chunk Seven 500MB Hash: 59D7DAC55E19243C881E45152B88DCFF
-Chunk Eight 415MB Hash: 7C850E039632A46E7F52900B2A1D2228
I added these smaller chunks so that people with slower download speeds or those who don't leave their computer on and downloading for a long long time can still download the entire DVD and get it little by little. In order to use these files to make the full DVD you must have all of the chunks downloaded and saved in the same folder. Unzip one of them (any one you want) and it should cause them all to unzip into the "iso" file. Before you unzip the files, make sure you check the MD5 Hash numbers with the numbers I've provided. If the numbers match, this ensures that the files are identical and they have no corruptions. Don't change the file names, as the MD5 numbers will not match. If the MD5 Hash numbers do not match, you'll need to re-download the file and check it again, other wise your DVD may stop and freeze up while watching. There is a link to an MD5 check tool and MD5 help is below.
The video files below have been encoded in the Divx format in order to save hosting space to fit more files. The reduced file size also helps you by reducing the time it takes to download all the files! You can download the Divx player at Divx.com. It is available for all platforms. You will need this player or a Divx codec inorder to view these videos.
-E30 M3 Rally
MD5 Hash: C4F3C5DF162CFECC296394389BB58396
File Type: AVI - 1.36GB
Play Time: 01:36:26
E30 M3 Rally broken down into 500MB chunks. Total zipped size is same: 1.36GB
Chunk One 500MB Hash: 2D3ADFA9C1C7472F67995BEA25D07690
Chunk Two 500MB Hash: 3E3AD8C43541B8E441CBE87F54DEBEF5
Chunk Three 500MB Hash: A982C6D5A64E500FC357AB4F2CD50550
I added these smaller chunks for the same reason as I added chunks for the BMW Films - The Hire DVD above. In order to use these files to make the full movie you must have all of the chunks downloaded and saved in the same folder. Unzip one of them (any one you want) and it should cause them all to unzip into the "avi" file. Before you unzip the files, make sure you check the MD5 Hash numbers with the numbers I've provided. If the numbers match, this ensures that the files are identical and they have no corruptions. Don't change the file names, as the MD5 numbers will not match. If the MD5 Hash numbers do not match, you'll need to re-download the file and check it again, other wise your DVD may stop and freeze up while watching. There is a link to an MD5 check tool and MD5 help is below.
-Pimp My Ride - Escort-to-BMW
File Type: AVI - 174MB
Play Time: 00:20:08
Description: Ugly Ford Escort gets pimped out and transformed into a Bimmer want to be. This project was such a disgrace to BMW and the BMW parts on the car. Makes me cry every time I watch it. However, it was definitely an upgrade to the car's appearance, but just straight-up wrong! :'(
Wiring Guides
-Car Radio Connector Removal - 179KB
-Computer Engine Control (1992 BMW 535i),Throttle SW (Grid 8-11) - 43KB
-Radio Connector Pin-Out Guide - 7.8KB
-Radio Wire Harness Diagrams - 175KB
This list will be updated with the site. Enjoy!
Updated: August 4, 2007
lil_clubsport_nugg
n00b-1st Gear
n00b-1st Gear
Re: Download List
Post by lil_clubsport_nugg »
i registered and logged in but still no link
Users browsing this forum: Amazon [Bot], CommonCrawl [Bot] and 0 guests
