First Video: 2011 BMW 335is on track
BMW launched earlier today one of the most awaited cars in the last few weeks: their 2011 BMW 335is. The 2011 BMW 335is is powered by the same award winning N54 inline-6 3.0-liter twin-turbo motor that comes standard in the 335i, although the motor is now enhanced.
It comes packing 320hp at 5,900 rpm and 332lb-ft of torque is available from 1,500-5,000 rpm. The engineers have tweaked the twin-turbo 3-liter motor to have an overboost function that increases torque to 370lb-ft. The overboost function comes into play at higher engine speeds and gears. BMW has also fitted a sport exhaust system that has a deeper “rumble” at low speeds and rpm.
The 335is will come with BMW’s heralded 7-speed double-clutch transmission, or DCT, with launch control, as an option over the standard 6-speed manual transmission. BMW claims a 5.0 second time to 60 with the optional DCT and launch control, while the manual coupe will take 5.1 seconds. The E93 is not far behind, with a 5.2 second 0-60 time with the DCT or the 6-speed manual.
BMW has updated the front fascia of the 335is with a wider mouth to feed more air, but also they’ve moved the fog lamps more to the sides to add more openings to feed lots more air into the engine. To use the extra air properly, BMW has fitted an additional radiator behind the left-front air intake, along with a more powerful electric cooling fan. An oil cooling pan has been added opposite of the second radiator, as well.
All of the updates that we reported for the E92 and E93 335i, like the LED taillights, corona lights along with the redesigned hood and kidney grill are standard, as you would expect, on the 335is models.
BMW is outfitting the 335is with M aerodynamics, meaning new front and rear fascia and sideskirts. Uniquely, there is a new rear diffuser that controls air flow and help reduce lift at the rear-end.
High gloss black surrounds the kidney grill and the wing mirrors, as well as black Shadowline window trim. 18″ ferric grey alloy wheels are standard, with 19″ M alloy wheels being optional.
The BMW 335is will debut at the New York International Auto Show and arrive at BMW Centers later in the spring. Pricing will begin at $50,525 including Destination for the 335is Coupe, and $59,075 including Destination for the Convertible.
First video 2011 BMW 335is
Source: http://www.bmwblog.com/2010/01/23/first ... -on-track/
