oil leak on my 328i from the oil filter to engine location
I have a oil leak where the oil filter unit meets the engine as best i can tell. I have been looking for a DIY for this, but it must be rare. All help appreciated!
Wow, no one else has seen this issue?
I find it hard to believe that 52 people have read this thread and no one has encountered a similar issue. I tore it all apart today and ordered the new gasket. The old one was really brittle (and broke into several pieces upon careful removal). I am confident that this is where the leak was coming from due to all the oil in that area. I will know next week when I put it all back together. With all the parts removed, I was finally able to clean the area so I can see if it does leak anywhere. The removal was rather easy if anyone wants to know.
later
later
You should replace the oil filter o-rings every time you replace the filter. Infact, the filter should always come with new o-rings. I'm not sure how they would go bad if they are changed everytime the filter is changed.
@2000_328i
Here is the suggested oil filter for your car.
BavAuto.com: Oil Filter - With Seal Rings for 2000 328i
@2000_328i
