Trying to find out how to use the A/V input, which is indicated on the T.V. screen in my 1997 E39. Is it an aditional module? Wiring loom?
I understand the same TV/entertainment system was installed on the E38 740s complete with the A/V input sockets in the centre arm rest. Any one help?
540 A/V input
hey Ric, maybe I can help you some. there is a Navigation Install guide for the E38 7-Series that (as you said) is very close to the same system, and it may give you some helpful hints. You can find it here at the bottom of the page...
http://www.bimmermania.com/downloads-se ... anuals.php
..hopefully that helps, but if it doesn't get it all sorted out then i'll see if I can help you get it figured out.
