World Premiere: 2012 MINI Coupe
At a glance.
  • MINI gives the small car segment another fascinating injection of variety with the presentation of the first two-seater in the brand’s current model range. The MINI Coupé represents the faithful transposition of the brand’s sporting DNA into a cutting-edge vehicle concept with a new interpretation of the super-compact sports car class; unrivalled handling agility and the best performance figures of any model in the MINI line-up; innovative design with a distinctive “helmet roof” form and optimised aerodynamic properties; a wide-opening tailgate and large, variable-use luggage area ensuring extensive versatility.
  • Latest generation of four-cylinder engines; most powerful petrol and diesel units in the MINI range; engine technology underpinned by the development expertise of the BMW Group / derived directly from motor sport; MINI John Cooper Works Coupé with 155 kW/211 hp, MINI Cooper S Coupé with 135 kW/184 hp, MINI Cooper Coupé with 90 kW/122 hp, MINI Cooper SD Coupé with 105 kW/143 hp; exceptional efficiency thanks to wide range of standard MINIMALISM technology; six-speed manual gearbox fitted as standard, six-speed automatic optional for MINI Cooper S Coupé, MINI Cooper Coupé and MINI Cooper SD Coupé.
  • A chassis set-up, weight balance and body structure geared squarely to providing unbeatable driving fun gives the car’s go-kart feeling unrivalled depth; Electric Power Steering and DSC (Dynamic Stability Control) as standard, DTC (Dynamic Traction Control) with EDLC (Electronic Differential Lock Control) optional (standard on MINI John Cooper Works Coupé); innovative pedestrian protection systems and measures to enhance body rigidity shift the car’s weight balance slightly further forward, giving the front-wheel-drive MINI Coupé optimised traction; agility and safety boosted by increase in torsional rigidity using carefully targeted, model-specific strengthening elements.
  • First “three-box” MINI with strikingly stepped rear end in the classic style of a gran turismo; sporty, flat coupé silhouette; sits 29 millimetres lower than MINI; new, faithful expression of the hallmark MINI design language; distinctive “helmet roof” with integral roof spoiler; first MINI with an active rear spoiler to optimise airflow at higher speeds; rear spoiler extends automatically at 80 km/h (50 mph).
  • Strict two-seater concept with extended stowage and loading capacity behind the driver and passenger seats; large, variable-use luggage area; large through-loading facility into the passenger compartment; wide and extremely high-opening tailgate makes loading easier.
Engine variants:
MINI John Cooper Works Coupé: Four-cylinder petrol engine with twin-scroll turbocharger and direct injection, plus numerous technological details carried over directly from motor sport.
Displacement: 1,598 cc, output: 155 kW/211 hp at 6,000 rpm, max. torque: 260 Nm/192 lb-ft at 1,850 – 5,600 rpm (280 Nm/207 lb-ft with Overboost at 1,700 – 4,500 rpm).
Acceleration: 0–100 km/h (62 mph): 6.4 seconds, top speed: 240 km/h (149 mph).
Average fuel consumption according to EU standard: 7.1 litres per 100 kilometres (39.8 mpg imp), CO2 emissions: 165 g/km.
MINI Cooper S Coupé: Four-cylinder petrol engine with twin-scroll turbocharger, direct injection and fully variable valve management based on the BMW Group’s VALVETRONIC technology.
Displacement: 1,598 cc, output: 135 kW/184 hp at 5,500 rpm, max. torque: 240 Nm/177 lb-ft at 1,600 – 5,000 rpm (260 Nm/192 lb-ft with Overboost at 1,700 – 4,500 rpm).
Acceleration: 0–100 km/h (62 mph): 6.9 seconds, top speed: 230 km/h (143 mph).
Average fuel consumption according to EU standard: 5.8 litres per 100 kilometres (48.7 mpg imp), CO2 emissions: 136 g/km.
MINI Cooper Coupé: Four-cylinder petrol engine with fully variable valve management based on the BMW Group’s VALVETRONIC technology.
Displacement: 1,598 cc, output: 90 kW/122 hp at 6,000 rpm, max. torque: 160 Nm/118 lb-ft at 4,250 rpm,
Acceleration: 0–100 km/h (62 mph): 9.0 seconds, top speed: 204 km/h (127 mph),
Average fuel consumption according to EU standard: 5.4 litres per 100 kilometres (52.3 mpg imp), CO2 emissions: 127 g/km.
MINI Cooper SD Coupé: Four-cylinder turbodiesel with aluminium crankcase, common-rail injection and variable turbine geometry.
Displacement: 1,995 cc, output: 105 kW/143 hp at 4,000 rpm, max. torque: 305 Nm/225 lb-ft at 1,750 – 2,700 rpm.
Acceleration: 0–100 km/h (62 mph): 7.9 seconds, top speed: 216 km/h (134 mph).
Average fuel consumption according to EU standard: 4.3 litres per 100 kilometres (65.7 mpg imp), CO2 emissions: 114 g/km.
[Source: MINI ]Image
Source: http://www.bmwblog.com/2011/06/21/world ... ini-coupe/
