Need a hand De-installing non-factory alarm
n20neenee
Post by n20neenee »
Gents
I have a Euro spec 1991 320I, which is basically a 1992 325.
Im trying to remove the non-factory alarm system as it is crazy and I do not like getting stranded
I found where they spliced the starter wire and fixed that, but I the engine just turns over and wont fire.
I can not find any more obvious splices other than one on the passenger side glove box area.
Where is the most common place to cut/install the immblizer wiring?
thanks
Sean
n20neenee
Re: Need a hand De-installing non-factory alarm
Post by n20neenee »
I figured it out.
The PO had spliced into the engine bay relays and used really long wires to run the connection back to the alarm
Users browsing this forum: No registered users and 20 guests
