Bentley Manual for e36..not working, what do I do.
Post questions about files in the 'Downloads' section of the site. Also, suggest files you've found to add to the downloads page or request downloads.
jfdmas
Post by jfdmas »
hi, im trying to DL the bentley manual for the e36 with no luck. am I doing something wrong or is it down?
never mind, i just downloaded the latest adobe. Thanks
Hey jfdmas,
Glad to see you figured out what was wrong. All fo the downloads should be available and working unless otherwise noted (near the download link itself). Thanks for posting about the fix as well. I suppose many people fail to realize that adobe reader is required in order to open the pdf files. Stick around tho. ;)
Future note to others with similar problems:
For those of you with similar problems, please try installing adobe reader onto your computer before posting. If your problem continues please search the forum for your problem, as it may already be explained with a solution.
Adobe Reader (Free) - http://www.adobe.com/
Swap_File
Post by Swap_File »
If you ever have trouble with Adobe Reader, you can try out Foxit PDF Reader too.
It works about the same, but it is a lot smaller and quicker for viewing. But it does seem to be a little slower for printing.
http://www.foxitsoftware.com/pdf/rd_intro.php
Users browsing this forum: No registered users and 16 guests
