Clutch sticking to floor..leaking brake fluid. [SOLVED]
dan1braden
- 1st Gear Member
The newest and greatest of my problems is making me go insane. I get into my car this morning and go to press the clutch and there is no force. My car doesnt even roll back so it must not be engaging!.. in fact when i press the clutch down it actually sticks and won't come back on its own. So, i am in dier need for some help!!...Please Anyone!!!
I had a similar problem a while back. My clutch in my case was losing pressure. Check and see if your brake fluid is filled to the proper level first. It might simply be low on brake fluid...which is what the clutch uses to build pressure. It might be that this brake fluid is leaking like mine was..and was not too expensive to get fixed. First just check the brake fluid, then check back. We'll get it worked out.
dan1braden
- 1st Gear Member
dan1braden
- 1st Gear Member
my car is somehow leaking dot4 braking fluid. I get into my car to go to the store and the clutch is once again sticking to the floor. So its not getting fluid. I look under the car it leaked the fluid. So how hard is it to fix the fluid going to my clutch? or is it worth to have bmw do it for me!
That's the exact same problem I had with my car. I took it by a shop and they had it fixed in no time. It's a small pin or something that breaks and allows the fluid to leak.
Just take it by the shop and let them fix it for you. Not too expensive.
dan1braden
- 1st Gear Member
Users browsing this forum: No registered users and 18 guests
