Setting the Time [SOLVED]
I am a first time BMW owner and i just wanted to know how do you set the time in the 1998 bmw 318i. I am dying to know please help.
The clock is set differently depending on what MID (multi information display) you have. How many buttons?
If it's 7 buttons, then hold down the hr/date button for 5 seconds until the : starts blinking. Then use the hr/min buttons to adjust the time and press Set to set it. While changing the time, use the C/F button to switch between am/pm and 24 hour time.
..alternatively..
push and hold "clock" until it says "input time". to switch between am/pm hit the "1000" key until you are at the right hour. use the 1, 10, and 100 keys to enter in the right time, the hit "set". clock should be set.
Hope that helps you out.
(This is also posted in the e36 M3 section, but for completeness to the forum is also here for the non M3 e36's)
..alternatively..
Users browsing this forum: No registered users and 20 guests
