Apple iPad 3G and iPhone 4 in a BMW 320d
Apple fans share more in common with BMW advocates that one can imagine. The passion for the two brands sometimes takes a deep dive into “fanboyism ocean”, and in the end, it’s the passion for the brand that drives some of our decisions.
Both companies are known for their premium products, one in the automotive space, being a leader in innovation and sustainability, while the other one takes pride in being a leader and innovator in the electronics field. A recent memo from BMW reinforces the strong connection between the two companies with the latest advanced integration between BMW’s iDrive system and Apple’s iPod and iPhone line-up.
But in the end, it all comes down to that very single individual that takes this integration to a new level. Glenn over at ….Glenn’s blogshares with us his latest geeky rig inside a BMW 320d, an E46 model.
Here is what Glenn says:
“I finally got my iPad 3G & iPhone 4 and they fit perfect in my old BMW 320d E46.
My iPad 3G is in a cheap Macally mSuit silicon case to protect the back and to prevent it from sliding. The iPhone 4 is in a Brodit Proclip holder that i used from my older iPhone 3GS, looks like the iPhone 4 fits in this 3G / 3GS holder.
To prevent the iPad from moving i can twist my iPhone 4 in the Brodit Proclip holder just a bit that it pushes the outer silicon case of the iPad 3G. (pure luck!) :)
The audio connects through bluetooth with the Alpine bluetooth module: KCE-400 BT that is connected with the Alpine car radio: IDA-X305.
The negative part is that i have to select 1 device to connect to the bluetooth module of the car. Either i turn on bluetooth on the iPad 3G or on the iPhone 4, I can’t connect both at the same time.”
But in the end, none of these imperfections matter, all it remains is the happiness of being able to combine the best of the two brands and create an unique setup which is likely to be seen in other bimmers as well.
P.S. Let’s not turn this into a discussion on “Antennagate”, Steve Jobs has had his fair share of iPhone 4 negative reviews and we’ll cut him some slack since he’s clearly a beamer lover. See his 1966 BMW R60/2 motorcycle
[Photo Source: glenn.eu ]
Source: http://www.bmwblog.com/2010/07/20/apple ... -bmw-320d/
