2010 NYIAS: F10 BMW 550i U.S. Debut
Another model to make its U.S. debut today at the 2010 New York Auto Show was the 2011 BMW 550i, the high-end model in the 5 Series line-up.
The top-of-the-range BMW 550i arrives with BMW’s “reverse-flow” V-8 engine featuring twin turbochargers and High Precision direct injection for maximum output of 400 hp. The engine is matted to an 8-speed transmission used in the existing 750Li and 550i as well.
The ZF 8-Speed makes for a strong transmission allowing the driver to experience all-round improved fuel efficiency with higher gearing while also allowing for better acceleration. The two taller gears in the 8-speed are ideal for cruising speeds and BMW has managed to improve the weight savings of the transmission to such a point that there is no additional weight added from the extra two gears. For those wanting to extract and put down power manually, a 6-speed gearbox will be available in the U.S. market for the bigger 535i and 550i.
ImageDesign wise, the 550i will differentiate itself at the rear-end by the two trapezoidal exhaust tips, as seen in the new 7 Series as well.
Different wheels options will also be available for the new 550i.
The 2011 BMW 550i will start at $60,575, including $875 Destination & Handling.
Source: http://www.bmwblog.com/2010/04/03/2010- ... u-s-debut/
