Shock Replacement on 1994 325i
Posted: Wed Mar 21, 2007 7:09 am
by simoking
With winter coming up, and the ol' bemmer shicks sounding like **** and stepping in the rougher corners etc, it could be good time to flick it up on the jacks, remove the wheels, get them dealt to, and replace the shocks at the same time. I have been to Bimmer DIY, and a lot of the links are HTTP 404, like not there, has anyone got a site(s), that could list out the DIY Steps to replace these. The vehicle is lowered with 17's, so has shortened springs, thanks in advance
List of helpful links
Posted: Fri Mar 23, 2007 3:52 pm
Just doing a quick search http://www.google.com/search?client=ope ... 8&oe=utf-8, here's what I've compiled for you:
Front Springs and Shock Replacement
http://www.pelicanparts.com/bmw/techart ... Suspen.htm
Rear Springs and Shock Replacement
Front Suspension Overhaul
http://www.pelicanparts.com/bmw/techart ... erhaul.htm
Replacing Rear Shock Mounts
http://www.pelicanparts.com/bmw/techart ... Mounts.htm
Rogue Engineering Rear Shock Tower Plates
http://home.comcast.net/~matthew.c.smit ... /index.htm
Ground Control Rear Shock Mounts
http://home.earthlink.net/~frankie66/ca ... ounts.html
Rear Shock Mounts
http://www.uucmotorwerks.com/html_techt ... mounts.htm
Changed my rear shock mounts today - here is some pics
http://forums.bimmerforums.com/forum/sh ... did=183435
That should be helpful. ;)
