The Updates: 2011 BMW 3-Series LCI
With information about the updated 3-Series coupe and convertible comes new upgrades. Most see this as a design refresh, but there are some very appealing things just beneath the surface. Just to highlight the exterior enhancements that are easy to see; the front, lower fascia is now presented with subtle winglets on the air-dam, but more than that, the actual area for air flow is slightly larger than the outgoing design, also allowing for larger splitters at each end of the fascia.
If you look very closely, you can see the slight increase in kidney grille size. But if you look even more closely than that, you’ll see the actual top corners have been become rounded out, no longer with a bit of an edge. One more styling difference; the corona rings, or halos, as some like to call them, are now bright LED units, with the updated E90 3-Series headlights making a coupe appearance.
The rear-lights are also modified LED look and finish. Though they were LED lights before, BMW added their new ‘L’ shaped design theme to an all new, almost E46 LED taillight, underneath the Ls. Holding the exhaust ports is an all-new bumper with a horizontal expressive line that shows the wide back end.
One quick thing that I must highlight before I go on is the full redesign of the side mirrors. If you’ve driven the E92/E93 3-Series you may have been slightly annoyed to have to move your head around in a circle to really get a full view of what is actually in your mirror. Now, though, you don’t have to do that, as BMW has taken notice to this issue and created larger mirrors to aid your visibility.
While the new exterior features and functions are a nice touch for all of us who love the 3-Series, the real news is the N55 inline-6 engine that first appeared on the new 5-Series GT. It features a single turbo with twin-scroll technology, direct-fuel injection and Valvetronic variable intake technology, along with being all aluminum. The engine still makes 300hp and 300lb-ft of torque with a 7,000 rpm redline.
However, the engine now builds peak torque at 1,200 rpm all the way to 5,000 rpm, where the N54 builds peak torque at 1,400 rpm. Peak horsepower is still produced at 5,800 rpm. So not much has really changed, just BMW making more torque available from startup, which is great. Also expect a slight increase in gas mileage due in part to valvetronic. The N55 weighs roughly 427lbs, according to BMW. The 328i’s N52 inline-6 goes unchanged with its 230hp and 200lb-ft of torque.
BMW has really upped the abilities of their all-wheel drive system. While the press release does not seem to indicate any modifications, it is interesting to note that BMW estimates the 0-60 of their manual equipped 335s is 5.3 for the RWD coupe and 5.2 for the AWD coupe. With the steptronic transmission (which now sports real + and – paddles, instead of the thumb and finger operated units), the gap widens. In automatic form, the 335i coupe accelerates to 60 in 5.5-seconds as a rear-wheel drive, versus the all-wheel drive’s 5.3-second 0-60 sprint. Of course, though, the actual numbers will be much faster than what BMW estimates. So look for your 335i to be right about where the older N54 model was in terms of performance, just slightly faster. So, hopefully we’re looking at a 4.7-second 0-60 time of both rear and all-wheel drive models.
One very cool design feature to the new 3-Series convertible, is the use of, what BMW calls, Sun-Reflective Leather. This allows the leather materials to stay much cooler when the sun is beating directly on it. This makes BMW the first automaker in the world to offer such booty-loving technology. If you’ve ever had a BMW convertible, or any BMW for that matter, you’ll know that the leather gets HOT!
The Sun-Reflective technology allows for the infrared radiation to flow in wavelengths of 720 nanometers. Whatever that means…
Basically, if you have darker leather seats, they will stay about 37 degrees cooler, and 27 degrees cooler with lighter interior. So the armrest, seats, headrests and shifter won’t send you to the ER after getting in.
Looking good so far and we’re glad to see this LCI is more than just a subtle refresh.Image
Author: Josh
Source: http://www.bmwblog.com/2010/01/16/the-u ... eries-lci/
Users browsing this forum: Bing [Bot] and 2 guests
