BMW 6-Series convertible spied …in snow this time
BMW test mules are moving up north for the winter testing sessions at Arctic Driving Center in Rovaniemi, Finland. AutoExpress and their team of spy photographers spotted the 2011 BMW 6 Series Convertible during some….snow drifting.
It is worth mentioning that their report is a bit misleading in regards to the soft-top. Despite the several prototypes seen in the past with a soft top, BMW will offer the new 6 Series sportscar with a similar hardtop found in the 3 Series Cabrio.
As we mentioned several times before, for now it has been confirmed that the 2011 BMW 6 Series will come in three flavors: Coupe, Convertible and M6. There are still some rumors around a Gran Turismo model based on the 6 Series, but prototypes have yet to be seen.
The next 6-series coupe and convertible will be radically different from the current cars’ styling. Even people close to BMW said that the current 6-Series is very polarizing due to the “Bangle butt” it carries, but the redesigned 6er, will be a “super sleek” vehicle. The redesigned 6er is slightly longer and wider than the current generation. It will have shorter overhangs and a lower roofline which implicitly gives the car a more muscular look.
The current engines line-up will be the base in the next generation 6 Series. The award winning twin-turbo 6-cylinder will power one of the entry levels models with its 326 horsepower, while the V8 twin-turbo 407 horsepower engine found in the new 5 and 7 Series will be found in the higher-end models. It has not been yet confirmed with multiple sources, but the rumor mill has it that BMW is developing a tri-turbo diesel engine based on the six-cylinder turbo existing in the BMW line-up and one of the top 6er models.The tri-turbo engine will output 354 horsepower and it will be initially used in a BMW X5 Performance Diesel.
BMW’s Efficient Dynamics updates, including Stop/Start and regenerative braking will also be available on the 6-Series for the first time. The M6 will replace its powerful and large V10 engine with a turbocharged powerplant.
The new 6-Series will make its online debut late next year and it will officially unveiled at 2011 Geneva Motor Show.
[Source: AutoExpress UK ]
Source: http://www.bmwblog.com/2009/11/30/bmw-6 ... this-time/
