Geneva Motor Show 2010: BMW X6 with Performance Parts
BMW X6 with Performance Parts also made its debut at the Geneva Motor Show. The sporting looks of the BMW X6 SAC are accentuated more than ever before by the Performance Aerodynamics Kit.
The BMW Performance Aerodynamics Kit is made up of the front bumper, side-sills and an insert for the rear bumper, all in special design and all finished in body color. The BMW Performance Aerodynamics Kit for the BMW X6 may also be supplemented by a rear spoiler, rear fins in matt black and a front grid finished in high-gloss black paint.
BMW Performance light-alloy wheels in Y-spoke design further optimize the dynamic driving potential and the striking looks of the BMW X6. Reduced in weight, these cast light-alloy 12-inch wheels stand out in particular through their roll-milled rim hump and exclusive twin-tone finish with a glossy outside surface and Ferric Grey paintwork between the rims. A special production method reduces the weight of each wheel by approximately 1,500 grams compared with conventional wheels of the same size.
The BMW Performance Power Kit available as a retrofittbale option on the gasoline versions of the BMW X6 as of June 2010 increases both torque and acceleration to an even higher standard. Developed specifically for the V8 power unit in the BMW X6 xDrive50i and the straight-six in the BMW X6 xDrive35i, the Performance Power Kit significantly improves both acceleration and elasticity.
The BMW Performance Power Kit raises maximum output of the eight-cylinder with BMW TwinPower Turbo and High Precision Injection in the BMW X6 xDrive50i by 30 kW/41 hp to 330 kW/448 hp. Peak torque, in turn, is up by 50 Newton-meters/37 lb-ft to 650 Nm/479 lb-ft. The six-cylinder power unit of the BMW X6 xDrive35i equipped with Twin Turbo technology and High Precision Injection shows an increase in maximum output by 15 kW/20 hp to 240 kW/326 hp, with peak torque increasing by 50 to 450 Newton-metres/332 lb-ft.
Benefiting from the BMW Performance Power Kit, both models accelerate 0.2 seconds faster from a standstill to 100 km/h, the BMW X6 xDrive50i with the BMW Performance Power Kit completing this sprint in 5.2 seconds, the BMW X6 xDrive35i in 6.5 seconds. Acceleration in gears from 80 – 120 km/h (50 – 75 mph) is 0.5 seconds faster in each model.
Likewise starting in June 2010, BMW Performance also offers a sports exhaust system. Available also on the BMW X6 xDrive50i and BMW X6 xDrive35i, this option stands out clearly through its chrome-plated tailpipes, at the same time offering even lower weight and a particularly striking sound pattern together with a further reduction of exhaust counter-pressure.
BMW Performance offers attractive accessories also for the car’s interior design, again raising the sporting driving experience in the BMW X6 to an even higher standard. As an example, all model variants of BMW’s Sports Activity Coupé may be equipped with a BMW Performance sports steering wheel with a flattened rim at the bottom and alcantara coating for optimum grip and a pleasant touch in all temperatures.
The driver’s workplace is further optimized in the true style of a genuine sports car by BMW Performance aluminum pedals and the BMW Performance driver’s footrest. In their technical features and design all of the BMW Performance components available in the BMW X6 comply in full with the typical style of the brand and naturally fulfill all of BMW’s supreme standards in terms of quality and safety.
Stunning car and not as flashy as some of the X6 seen at different car tuners.
Source: http://www.bmwblog.com/2010/03/03/genev ... nce-parts/
Users browsing this forum: Semrush [Bot] and 7 guests
